- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s; 65-C20 with 4:57 gears and Borg Warner Overdrive
- Carb'ed Vortec 350; 1972 L48 350
You'll spend as much as you need to, to get it as nice as you want it. Paint is not cheap. Even if you do all the prep, for them to shoot it, it's pricey. Have them do all the work, it could be around 10k depending on the shop. You could always cheap out and go to Maaco or Earl Scheib. Engine, transmission, bling, solid reliable runner, easily 20k. I personally don't keep tabs on what I have spent because it will be way more than I thought it would be.
