82sbshortbed
Fuckemall!!
- Mar 1, 2018
- SE Texas
- Doug
- 1500 shortbed, 1500 longbed
Well, how did it do?
if my life is any indicator, redheads are very pricey, very tempramental, and will easily suck the life out of you. X2 on redhead. If you want to replace it only once buy redhead. They are a little pricey,but they are the best gear box on the market.
The whole frame cracking thing has been discussed here before, but I'm not sure if it has been in this thread so I'll say what I know from my experience, both personally and at the shop. I think it is blown way out of proportion. Yes, I know it happens, and can be dangerous but I don't think it happens overnight, and I think only after some serious abuse at some point. Chris, I'm not saying you abused your previous truck, but I think to get to the point where the box actually comes off the frame the damage has been building. Perhaps before you owned it, something happened when the former owner had it. When you really think about the Saginaw power steering pump, the amount of pressure it produces and how easy it is to turn the wheel in these trucks even with big tires, it's not hard to image how someone could inadvertently stress the heck out of the frame by turning the wheels with a great deal of force into and unmovable object like a curb. One or two of the bolts perhaps cracks the frame either fully or partially. Now there is movement where there isn't suppose to be and over time more cracks and stress occurs because the box is no longer properly attached to the frame and eventually in worse case scenario total steering failure.
The good news is the most likely time for this, or any other steering component to fail is at low speed where there is more resistance on the tires when the wheel is turned.
Side note: Did you know that at least up into the late 60's the larger Gillig built school buses with power steering, they came with the warning that the bus should be rolling when the steering wheel was turned. They were so heavy and steering so easy to turn that they were concerned about "steering system component damage" from turning the tires with the bus stopped. Obviously I know a square is not a school bus, but I thought you might find that warning interesting.
I'm fed a relatively steady diet of square body trucks and a few 60's GM trucks at work. These vary from very nice driver type condition where they are to nice to really want to haul anything in to farm trucks. The farm trucks can be pickups or medium duty rigs. Of course as you'd expect the farm trucks are all 2wds and I've heard that the problem mostly pertains to 4wd trucks. I'm yet to see a box actually come off. But then I've never seen a square catch fire because of a side impact, which of course we know has happened. Like the fuel tank thing, I think the side saddle tanks are safer than they were in the cab like in the 60's. I think pulling the box and closely inspecting the frame is enough in a truck not used hard, but just like some folks like to move the fuel tank to the rear because it is safer, if it makes you feel safer install the steering brace, it's a small cost for your peace of mind. I just thought you'd might be interesting to read one mechanics take on the steering box / frame crack issue.
I have no experience with Lares, we use Redhead, but they are close enough to the shop that they will deliver to us.
As you might image I'm not surprised to hear that at all. Since I'd already written several paragraphs I thought about saying this but did not. Seems much more prevalent in trucks that go off road and are off roaded hard. Have big tires, ect.Your experience and words ring true Rob!
In my mid 20's I thought I was indestructible so I probably thought everything else must have been as well...I did a decent amount of wheeling around in the sand dunes and the daily trip up and down the mountain would have been hard on a Vette, much less a K5 with 33's (if IIRC), not to mention it had been in one accident I know of so I think you are spot on that it didn't happen overnight.
I jumped back in the square body world about a year ago and the box popping off the frame was one of those experiences you never forget and after reading a lot of the forum posts, I thought that it was just a given it would happen at one point (kind of like rust at the cowl seam). I appreciate your wisdom and experience and it gives me a tremendous amount of confidence in putting my kids in the truck with me at this point. My desert dune days are behind me but an occasional ski trip is right up my alley and now I know what to look for.
This forum, and more importantly it's members, have guided (and continue to guide) me through a rewarding rebuild! SOOO many thanks to everyone!
these kinds of shimsYes to shims, no to steel.
I'm not sure what the material was, but I'm pretty sure they were not steel.
Haha...once again I am hearing you!As you might image I'm not surprised to hear that at all. Since I'd already written several paragraphs I thought about saying this but did not. Seems much more prevalent in trucks that go off road and are off roaded hard. Have big tires, ect.
I'm pretty much a double check that I locked the gate before I leave, wear my seat belt, look out for what the other guy might do to me on the road, but I really don't worry about the gear box thing or the side saddle tanks, but on the other hand if I'd had a bad experience with either the tanks or the boxes I'd likely feel differently. And like I said if the bracket will give you some comfort get it. Since it's a used truck, IMO it is worth looking at that area around the bolts real close because you never know what the former owner might have put it through and you'll sleep better knowing it's all good there.
The cowling rust is a problem for sure, but IMO even more than that is rust in the windshield channel.
Ya, that's a small price for peace of mind!Haha...once again I am hearing you!
Fortunately in this case, since I'm taking the steering gear off anyways, I can get a good look at the frame and be reasonably confidant in it's integrity. And also since I have it all apart, I should probably add the steering brace because it looks like I can buy my way out of any (well, limited anyways) mental anguish for a mere $140...
