Neutral safety switch
mran613
MA
Mark
V20
Hi,
I just bought this switch but I cannot find installation instructions. The switch can be turned right and left; does anyone know how to configure and install this?
Thank you for your help.
Mark
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
There is a hole somewhere in the column the yellow tab drops into. You may need to move the shifter or the tab to get things to line up.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Bottom of column.
That style just snaps on/in.
Pull the shifter all the way to low.
Install the switch, put it in park.
Boom !
Adjusted.
boukeelynn
