Mutha trucking Vintage Air
eskimomann209
Modesto
Marcus
Any VA experienced people out here? The panel doesn’t “Direct” for as promised.
chop chop time?
eskimomann209
Modesto
Marcus
Or is THIS the way?
eskimomann209
Modesto
Marcus
eskimomann209
Modesto
Marcus
Mounted up the plate and drew on the holes. Two are supposed to be 2” openings and two are 1 1/8.
After drilling the two inch hole, I **** my pants. It’s way too large. I went back and forth with it saying but that’s what the book says and drilled it any way. I shouldn’t have. The next one I drilled 1 1/2”
The other two I trusted for the 1 1/8 it looks ok to me.
eskimomann209
Modesto
Marcus
For the two mounting holes that the evaporator mounts to I drilled and tapped them for a 1/4-20
I went inside the cab and lined up the bolt to the top evap bolt I could see
Propped the evap up on some tools went back inside and ran the bolts in.
This allowed me to do it myself.
eskimomann209
Modesto
Marcus
I used this little pick to make sure everything was lined up on the bottom bolt. Now let’s talk about this inner bracket.
Instructions say to pre drill a 3/16 then run the provided bolts through.
That’s a bitch my drill would not fit up there with a bit in it. Instead I opted for the self tapper/ driller whatever you wanna caller.
Made it much quicker.
Also I highly recommend not having this bracket on when lifting the evap into place and REMOVING the two bolts ( pass side only) for the dash attaching it to the cab so you can roll the metal dash up and out of the way a lil bit.
eskimomann209
Modesto
Marcus
Put the hoses on the defrost vents then dropped em down through and modified the cross vent. I don’t plan on using the upper driver side vent so I blocked it off the evap. I prefer the shelf I have there. I’m sure it’ll be cold enough when the time comes.
eskimomann209
Modesto
Marcus
Does anyone know of a company that sells grilles for the defrost vents?
Any custom one out there? I’m thinking of just laying some screen under the dash on top of the vent.
hoagster
California
K10, 1500
5.3l
Would be a good idea, what did you find when you pulled the old ones? My dad like Certs, I found 2 rolls of them a old lighter and a couple of 22 shells when I tore mine down.
eskimomann209
Modesto
Marcus
Leave it to my truck. Went to notch the box.... Mine appears to be much different than VA was expecting
Probably have to figure sumthn out!
eskimomann209
Modesto
Marcus
Haha I removed the all the guts over a year ago when I dynamat the interior. Back when I did it then I found some change and a thermometer.. I remember my dad used to keep it on the dash. It was originally a NON ac truck. I’m sure he did it to remind himself how much he wanted AC.
Craig 85
Nashville, TN
454/TH-400/NP205
When I had an aftermarket A/C installed on my '80 3+3 in the 90's, the shop sliced the box at the yellow line, then slid it inward and rivetted the sides. Photo 2 is an A/C box. I'm sure that small piece you have would be used to replace the right side of the A/C style box.
eskimomann209
Modesto
Marcus
That makes more sense.
My fault then, as is most issues LOL. I used all oem junkyard pets for the vents and figured I’d order the W factory AC kit since I didn’t want the Vents. And there we see it biting me in the ass. I’ll probably Rivet it in as yours was.
eskimomann209
Modesto
Marcus
Good news is I found my “vents”
They’re some leftover gutter grates I used for a rodent problem on a buddy’s house.
Probably could have left em aluminum for some contrast but I hit em with some paint.
