Tank replacement for EFI
Kevin S
Japan
Kevin
GMC C2500 High Sierra, Colonial Yellow
BBC 454, manual SM465
The Sniper on the other hand turned out to be the biggest piece of **** ever sold...but that's another story.
Was thinking of getting the Sniper EFI system for the 454 / MT... perhaps a separate post for EFI conversion and your experience?
nyceguy01
N. UT
J
I used a tank and Pump from tanksinc.com nice stuff
JTWard
SE Pennsylvania
James
C1500 Silverado
350 Gasoline
This may sound odd, but where is the fuel regulator with the new Holly fuel injection setup ?
bluex
Spartanburg SC
C15
Its in the throttle body at the return fitting.
4WDKC
Southern Florida
Kacy
With the older truck the fuel tank switch and valve probably wont have the power wire for the intank pumps to switch correctly. You would either need to wire that in to correct the issue or swap to the blazer tank under the rear of the bed.
Kasey 1977 K10
Kasey
Yes you can do that, its exactly what I did. Every thing brand new from rock auto was like $204 but I have a single tank so it would be double for you to do both.
So I got my new 87 tanks, sending units and EP381 pumps installed with the u7001 selector valve and everything is working great! My only issue is the wiring diagrams called for a 6 terminal switch. I picked one up but it is 2x the size of the original and is currently just hanging out of the dash. My question is can I get away with a 4 terminal switch or can anyone recommend a 6 terminal switch that would fit better in a square? Thanks!
Kasey 1977 K10
Kasey
Nevermind... got the 4 terminal switch working. Just having to do a bit of modification to get it to be flush on the dash.
gmachinz
Harnessworx Inc
Iowa
Jabin
For guys who want to go for a factory look I have the dual tank LSx/EFI conversion harnesses. Also, this eliminates power routing through the dash switch as well. Individual LH/RH pump control and upgraded wiring.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Price?
gmachinz
Harnessworx Inc
Iowa
Jabin
With 65 psi valve and switch $309 or $239 w/o. Kit includes underdash control section and chassis section all the way to valve and both pump leads.
Kasey 1977 K10
Kasey
For anyone going down this path below is what I did with help from member Bleux and others for my 1977 K10. Prices below are as of today from RockAuto.
2 - ACDELCO EP381 {#25163473} (Pumps) - $57.79 ea.
2 - SPECTRA PREMIUM GM11C {#471681} (Tanks w/ Lock Rings) - $76.69 ea.
1 - SPECTRA PREMIUM FG05N {#25090837} (Passenger Side Sending Unit) - $73.79
1 - SPECTRA PREMIUM FG05M {#19179694, 25090846} (Drivers Side Sending Unit) - $66.99
1 - ACDELCO U7001 {#12336291} (Fuel Selector Valve) - $77.79
1 - STANDARD MOTOR PRODUCTS DS1807 {#15599081, 19244972, D7089C} (Tank Selector Switch) - $9.37
2 - Filler hoses to fit 1987 tanks - Can't find the part number
Notes:
  • Had to make a slight modification to reduce the 87 filler hose to the 77 filler neck
  • Used the sniper pump power lead to power the switch so my selected pump only runs until prime is finished before I start it up
  • Had to make modifications to the back of the selector switch to fit in the dash and be flush
  • Shouldn't have purchased the full Sniper kit as I'm no longer using the inline pump
  • Looks completely stock
SquareRoot
I'm going this route in the next few days as summer is knocking on my door. My 85 has the Pro-flo 4 and remote sump. The sump no- likey summer time temps. Time to **** can it and do it right!
This thread is a great help. Thanks to the OP for posting it.
77 K20
Montana
K20 5" lift
HT383 fuel injected
What is the sump doing when it gets hot? Pump stops? Pressure drops? Idle surges?
I have their E-street TBI unit with the remote sump mounted on the passenger side between the headlight and the radiator. Haven't noticed anything out of the ordinary so far. Planning on changing out the TBI to the Pro-flo4 in the next year.
Of course your summertime temps and mine are quite different. And once it hits 90 here I don't drive the truck much (no AC or tinted windows)
SquareRoot
Cooking the sump/pump, vaporizing the fuel making hit starts hit or miss.
kurt54
