The88
Mhmm
South Louisiana
ThatGuy
Not on installation instructions so im going on a limb here, in order to get the best results, should I tighten up the sway bar a bit before I take it off jacks and then fully torque it to spec? Or tighten to spec on jack stands? (its only slightly lifted maybe 1-2 inches.
I figure itd be best to torque down at actual right hight....
Ride height. If you tighten with a droop it will ride like poop.
WebMonkey
Missouri Ozarks
changed from winter shoes to summer shoes on ol' Skidmark (aka 'the flying turd')
35x12.50-15 vs stock more or less
GXPWeasel
Kansas
Greg
1982 | 2015
Sierra C15 | Silverado Z71
5.0 | 5.3
Installed front brake pads, calipers, and hoses. Then spun the truck around to remove the bed. Time to clean up the back half of the frame, and tackle the rear dif fluid change and brakes.
Camar068
10 yrs Air Force
finished the harness for electric doors. I'll make some jumper wires tomorrow at work so I can hook them up, while they're off the truck, to test. Really sucks because you pretty much need to be a contortionist to unplug some of the connectors in the doors lol.....let alone having very low dexterity in my right hand.
I'm pretty sure one of the motors is bad so I'll be deep into it more. Luckily I picked up a pair last spring along with a step-side fender and other parts at a farmers place. I'll slap up some pics when I get a chance.
Washington
Not a damn thing! Been sitting like this for 2 weeks now. Almost ready for second coat of primer and final block sand on bed.
Cab needs roof and windshield repair and then it’s ready for primer.
All other pieces are prepped for primer.
Need to turn this thing blue again before the weather gets nice!
80BrownK10
Greenwood, SC
Nate
My black mirrors are already dull af from the sun. Anything to bring back the shine or do I just live w them/ buy something else?
4 months sitting outside i guess was too much to ask.
Oil, wax, tire shine?
hoagster
California
K10, 1500
5.3l
I put some eye bolts in the 4 of the bed mount locations and used the engine hoist made it super easy to remove and re-install
Ken B
indiana
ken
I used alligator clips and tested my door wiring....made a stand so they could stand upright outa an old pallet and some HD pipe hangin brackets. and used wires with alligator clips and a spare battery....
The88
Mhmm
South Louisiana
ThatGuy
Today the fan switch came in for the new cooling system. Just waiting on the radiator and fans.
Also sitting in the shed I have got a B&M super cooler and was wondering if I should throw that on there with it's own e fan or just run with the cooler in the radiator? Any opinions?
That's genius... I'm about to pull my bed and I'm definitely going to try it this way
Poppy 87
Bloomingdale GA
R10 Silverado
There is no such thing as too much cooling for an automatic transmission. If you already have it, and are installing the new radiator/fans install it. That's what I would do. May want to install a transmission temperature gauge as well. Easy for me to spend your time and money though!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Looking at new radiators for mine. Which one did you get?
Poppy 87
Bloomingdale GA
R10 Silverado
You have any pictures of the set up? Awesome idea!
mitchell1128
