- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
I have a K10 . I'm thinking about putting a Blazer cap on and make a longer looking Blazer. I would have a secure place to keep my stuff, out the mud , rain and crooks. It would also be a safe place to sleep overnight. I believe the Blazer cap is only 9" shorter than my K10 bed. I'll glass in that 9" and cut out the back of my cab. Reinforce it and paint. I'll definitely get some second looks. Maybe t a trend. WHAT Y'ALL THINK ??
It would be more involved than that. It's a couple layers of fiberglass with a mounting flange, plus the cab would need a mounting flange for the top to bolt to and seal against. But the biggest hurdle is the body mounts- the cab is on isolated mounts but the bed is mounted solid to the frame. And of course the cab and bed are independent of each other so they are free to move separately with frame flex, even if both were mounted solid.
