Jarrett Melvin
- Oct 17, 2020
- Newfoundland
- Jarrett
- C20
I have 350 TBI, it's registered as an 86 but I was told it was an 89, the TBI been giving all kinds of trouble and the PO had said he picked with it and stuff.
So I have an 83 with a 350 also with a carb. So my intention was to swap the intake and carb onto the TBI and make it all mechanical.
I have a new fuel tank with a mechanical sending unit, mechanical fuel pump, intake and the carb. I'm aware that if the crank don't have a lobe on it for the push rod pump and I may have to use an inline electric. Im gunna use a manual choke.
Questions I have, will the intakes change over?
The TBI has a distributor with a 9th wire on it going to he top of the intake, not sure what its for and will I need to swap the distributor aswell?
Is there any wiring or harness issues to deal with?
Thanks
Thanks
