- Jan 23, 2013
- Georgia
- Roger
- Jimmy Sierra
I'd get an alignment bore with a torque plate and deck the block and heads, cross drill and chamfer the oil passages on the crank, shot peen the rods, new pistons, rings and cam, new pushrods and rockers, re-do the valve seats, new oil pump and port match the intake and heads, grind out all of the casting flash and smooth out the exhaust ports, hot tank everything and full assembly balance. Not necessarily in that order; and do a lot of the work yourself and you'll come out a lot less than $1500.
Very nize lookin' truck!
Keep us posted with your progress and satisfy our jones with pix.
