82sbshortbed
Fuckemall!!
- Mar 1, 2018
- SE Texas
- Doug
- 1500 shortbed, 1500 longbed
Added 1 more qt of atf then took it for about a 30 minute ride to make sure that the Trans was good and hot. Stopped by HEB for some beer for the game later.
Then got bit of a scare for a minute. Went to crank it and one click then nothing. Popped the hood checked battery cable connection (good) the light to the alt was on with key on. Thought, do I need a jump? This was all of a sudden though.
Don't have any tools in it(that's gonna change)but, I found some metal bracket in center console. So I took it and hit the starter a couple good times with it. Got back in cranked right up. Whew, got it home and checked the Trans fluid level and it's perfect now.
That's a total of 8qts total with deep pan and filter change now. Just didn't think it'd take that much. Anyways I heard if you over filled it then the atf becomes foamy. No signs of that.
