Where does your overflow bottle mount on your square?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Did the civi 6.2s have dual passenger side batteries?
I think that dual batteries was standard on diesel models. I had the same thought on whether they would be the same or not.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
If you see and oval shaped perch on the front of you DS inner fender near the backside of your headlights and your bottle is shaped like mine, you need this metal bracket that bolts to the core support on top.
Well thanks now I know. Just last week organizing parts I found one of those brackets. Was wondering what in hellfuk it was for? NOW I KNOW.
Memaloose
Dolan Springs, AZ
Tony
It's interesting to see all the photos of the different locations and shapes.
Here's where mine is mounted on my '75 Scottsdale.
Octane
Atlanta
Eddie
Ny 77 K 10 is this same way.But no heater hose hookup there is only difference.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I ended up mounted on the battery box
This was the best place I could find for it.
MikeB
North Texas
My 82 had the tank mounted on the passenger side of the core support, almost underneath the battery. I ended up installing a 85 tank on the fender. It's larger, easier to access, and lets air bubbles escape from the radiator because it's the highest point in the system.
PrairieDrifter
North Dakota
Mason
One of the few with a twist on cap as well.
RoryH19
Rory
R10 Silverado SWB
naaa LQ9 cover on my LQ4 lolll just want to hide the ugly truck intake for cheap ($35) :D
I have a 04 LQ9 from an Escalade. It took me forever to find the cover you have.
Only used on the 02 Escalade others say Vortec
dougli1
