What does everyone do with this seam?
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
It’ll be solid for sure.
hunters628
Ellensburg Washington
Hunter
I’m gonna be welding mine closed on my k10. Don’t know what else to do with it.
Keith Seymore
Motor City
Keith Seymore
4.3L
Most folks leave it.
The only seam that was metal finished at the factory was the corresponding seam at the top of the A pillar, which was brazed and then ground down in the body shop.
K
Scott91370
Burleson, Tx
Scott
Sierra1500
I thought about filling it but left it. That was just me being cheap since I wasn't doing the body work myself. If I could do body work I would have welded it up and smoothed it out along with the one at the bottom of the cab.
Tank6x2
Kurt
C30
Where’s the one at the bottom? Rocker to cab corner?
Scott91370
Burleson, Tx
Scott
Sierra1500
Yes, runs vertical with the door gap. Not as noticeable because it does follow a gap but bugs me.
Tank6x2
Kurt
C30
Already filled it, it’s a little more finished that this though
garethrowsell
