how hard is it to rebuild a 205 - what might be needed from a shop
eskimomann209
Modesto
Marcus
I have built about three of them... I do not recall needing a press. Good snap ring pliers. Yes. Then there’s that funky snap ring that doesn’t have the eyes for the usual style of pliers. ( IF ORIGINAL RINGS) They look more like reversed slip joint pliers.
Maybe the idler gear needed a press? I really do not remember the need for one.
keep the area clean and parts organized. I twin stocked mine too.
you will need a dial indicator for back lash on the idler. But besides that. All pretty simple.
Rusty Nail
Rusty
350sbc
im not saying i cant carry it... but i havent tried and attached to the adapter it was a mfer to wiggle around as it was lol
Oh no...I was laughing at the thought of Bucket simply "carrying one around". Like hangin out with one, walking a dog, cuttin the grass, doin laundry, carrying around a transfer case, cleanin the bathroom, whatever. It struck me funny. :shrug:
Carrying them around,
LoL?
*phone rings*
"Hay Bucket, it's Rusty. I was over here lookin at the internet and wondered what was goin on over there. Wanna go to the carwash?"
Bucket replies "Not too much, only carryin around a transfer case."
o_O
LoL?
I combined two np205's into one good one. It wasnt that bad especially with this guys videos. https://www.youtube.com/gebbuilt
I used parts from offroad design or ebay.
did you do fixed output on both sides?
Fortunately i have about 7 snap ring pliers in different variations and some redundant. The hub locks would have been killer without them lol
eskimomann209
Modesto
Marcus
These are the ones I mean.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I think I was thinking about the sm465. I can't remember 100%, I know you for sure need a press for the 465.
ali_c20
Austria
Alexander
C20, K5
is that a lot for a novice like me?
It's a pretty easy t-case. I don't see a problem if you take your time and keep your workspace clean and organized.
well either way i should have a press
PrairieDrifter
North Dakota
Mason
It's the easiest case to rebuild in my opinion, just shift rails and gears and shafts. No shift forks or chains or any small plastic or any of that junk
eskimomann209
Modesto
Marcus
Hmmmm. But there is indeed shift forks... their little nubs on the tip is a wear point.
PrairieDrifter
North Dakota
Mason
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
The videos I've seen make it look super easy. Its all gears and bearings, so any serious damage should be fairly obvious once apart. I would just buy a quality rebuild kit, tear it down completely, clean and inspect everything, and throw it back together. It never hurts to scrub the outside and throw a quick coat of enamel on it at the same time either.
If I remember correctly the NP205 is a heavy B in the ~200lb range. I'll be rebuilding my 80' 205 this winter when the old drivetrain comes out before I put the new 454 in.
If the 80' 205 came off a TH400, it wont work on the SM465. They have a completely different output.
they both mated to sm465 i should have clarified, they only swapped which one has slip yoke on whichh side. drop is the same.
My 1980 it is on the front, my 1977 frame it was on the back. oddly, the frame had a slip driveshaft on both despite having a slip joint
yah the slip output is definitely a later years thing... the earlier years at least before 1983 or so were slip splines in the drivehaft just after the carrier bearing(in the rear drivelines) so the case itself is definitely from a later years' style truck.
and level of difficullty in disassembling and reassembling oof the case would totally/directly be dependent on your level of experience in R&R of transmissions/cases and etc... and also in the availability of any special tools that could be needed... and an iron T case such as a 205 or a 203( these are iron) is alot more than a 208 or a 241 or etc.(these are aluminum).. goin to be much more than any 140 lbs...
fast68chevy
LINCOLN IL
RANDY
oh wow i have had a pair of these exact same old vintage pair of pliers(the second and third pics that you posted in here) floating around here for many years now, and i never knew what they would be good for, or were meant for.. hmmmm... well now i know, haha!! the one thig i never got much into was the R&R of transmissions and cases and axles directly/internally.. hmm... so i never knew what these pliers that I've had floating around here for all these years were good for.. hmm...
https://shop.snapon.com/product/Snap-Ring-Pliers/Snap-Ring-Pliers/SRP2A
lookks like ab out 60 bucks for these same pliers now, at SNAP-ON, directly, currently.. hmm... interesting...
eskimomann209
Modesto
Marcus
Lol yeah. They’re funny. You never really use them. BUT when you need ‘em, you need ‘em.
ssgmike
