Brake Pedal
custodian
Catawba
William
5.3 LS, 350
Looking for the brake pedal setup for power brakes for an 85 C10.
custodian
Catawba
William
5.3 LS, 350
Auto, Power from a C10.
Are you doing a conversion or what? You want nothing but the pedal itself, or you need the hanger too?
custodian
Catawba
William
5.3 LS, 350
Converting from hydroboost to power brakes. Just need the arm, don't need the big bracket it bolts to.
custodian
Catawba
William
5.3 LS, 350
custodian
Catawba
William
5.3 LS, 350
Are these from a C10? Where is the pivot mounted on the top picture, centered, to the rear of the shaft? I don't need the large bracket the pedal is mounted to. I want the push rod.
The bottom one pictured looks to be a hydroboost.
I'll PM you.
ajd89
Central Michigan
andrew
I'll PM you.
Came from 86/87 k10s. And good eye on the last one. Lol I didnt even notice that had to go back out and look again. Didnt think I had one of them.
This is what you wanted to see?
Got your pm.
custodian
Catawba
William
5.3 LS, 350
Got your pm.
Yes.
custodian
Catawba
William
5.3 LS, 350
I believe MikeB in the brake section is also looking for one.
Jakebr8k
