86 dually axle bolt torque?
louu
South NJ
Lou
C3500
454 for now working on LS
Does anyone know the torque for these bolts?
it's a 1986 GMC C3500 or maybe a C30 there's no badges. It's a dually.
louu
South NJ
Lou
C3500
This is the rear axle
Big Chip
Michigan
Kevin
C35
Is it a gmc or chevy?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
3 ugga dugga's
Vbb199
Salisbury NC
Vince
Dana 70HD and 14 bolt full float is about 90ish or so foot pounds for those, wouldn't go anymore. They are 3/8 bolts after all
louu
South NJ
Lou
C3500
Awesome thanks man, seems like a lot, guess it has to be with all that big block power lol.
Yes, that is correct.
Thanks again bud
power and weight. full float axle(that is thje axle shaft that you are tightening) allows more weight to be bared because the differential and its tube does the work. THe shaft just turns the wheels from thje pinion.
T3rraBeara
