Will this produce the results I want
That's real similiar to your build, and figuring 15 percent for drivetrain loss your numbers should be real close to what your wanting
Mark Jones
Horse Shoe Bay Tx/Thousand Oaks Ca
Mark
I want 300whp and 350wtq. Its not for a hotrod but the 305 in the truck has to go!!
4 bolt goodwrench block with stock rotating assembly
Comp xe262 cam and lifters
Summit 007 72cc 2.02intake 1.60ex heads with comp 1.6 roller rockers,guide plates,screw in studs, comp springs, etc
performer rpm air gap
1906 av2 carb
summit hei distributor with medium springs and adjustable vac advance
summit stainless headers and a 2.25 exhaust kit
If not oh well because the parts already here.
NO
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
i think you will have a hard time getting 350 ft/lb torque out of that combo. also what is the gear ratio? the right engine with the wrong gears will fall flat on it's face
3.73 gears with 700r4 trans.
Mark Jones
Mark
care to elaborate?
A truck has a lot of loses in the drive train, on a calibrated chassis dyno I don't think you will get there with that engine combination. IMO chassis dyno numbers mean nothing, but are only good for tuning the entire combination.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
I agree on both accounts. I dont expect it to ever see a dyno of any kind on my budget.
I imagine my loss will be in the higher range. Its a longbed with no supporting mods to help deliver the power where needed.
Thankfully HP isnt my main concern as much as torque. The truck will never rev past 5-5500k, intentionally anyways.
I am a bit concerned with the fact that the parts I have are intended for a 1800-6500rpm range and Ill have relatively low compression. may make getting out the hole a bit soft. IE torque concerns!!
My saving grace...( as previosly mentioned by one of the responders), Is that I will be undoubtedly doubling the numbers across the power band when compared to the anemic and worn 305 that is currently in it. I expect to be happy regardless when that is considered. Numbers Shmumbers it should be a good driver...I hope!
rumpity_z28
