77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
I'm going from a 3" block to a 4" shackle flip. I'm sure it will have some adjusting that needs to be done. I'll worry about it when I get around to replacing the 1.25-ton springs with a lift kit from ORD.
Is the plate for moving the axle forward and backward or to rotate the axle and set the pinion angle.
Sounds like a good plan- especially because it seems like sometimes the axle gets moved forward more on some trucks (mine's just a K20).
The plate is just for centering how the tire is placed in the wheel well.
The pinion angle is going to be tilted upwards automatically with the shackle flip- on a long bed with a 4" flip there is a chance it might be too much. Will know after you drive it.
