IndianCountry
- Sep 22, 2019
- Tanana, Alaska
- Kennozeedze
- V1500 Suburban
got the power plant for the subourban. wrecked donor vehicle. probably going to get that 14 bolt too.
anyways, only the harness, engine, and trans need to be taken out right now. has a push button transfercase.
im thinking, take the shafts off, take off the junk t case that drops on the wrong side, and then try to get the engine and trans out from the front/top. i will be removing everything in the way IF necessary. for example, if it isn't absolutely required, i dont want to take off the harmonic balancer pulley if i can instead take off the front clip. or will it be easier to separate before removal? if you have experience with these trucks and engines, please share what you gotta say
