- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I see kits to mount saginaw up high, down low, and then the stock on mine which is center.
Could someone buy a remote-reservoir meant for certain applications and use it to power a hydraulic accessory? I learned from you guys in a post in the past that using PS pump as-is to power a plow cylinder would likely mean you steer OR you lift, probably cant do both, and the PS pump has too litle capacity. I have a custom reservoir intended for this purpose, just dont have a pump to power the setup. These remote reservoir pumps.. did any come for small blocks, or maybe hydroboost?
Did they use the same mounting hardware as a normal saginaw?
Otherwise, i have a 60s mopar pump without a reservoir that I would probably need custom brackets for.. any thoguhts on that Haha?
And off chance, anyone know of a PS clutch? Or perhaps the size of pulley shaft and maybe i could find a clutch that would fit? Googling yielded little, but i could be looking in the wrong spaces.
