- May 18, 2020
- Washington
- Todd
- K20
So you’re confident you have spark at every spark plug? That’s good.
You’ve checked firing order to make sure there aren’t a couple wires out of order presume?
Timing and advance? You mentioned a timing light but is it timed or not? Does it advance properly?
You sound new to this so it’s understandably a bit daunting.
Anyone around you that knows there way around old ignition systems?
I still wouldn’t discount fuel pressure and O2. Could absolutely be contributory. Haven’t heard if you verified fuel pressure yet.
