Front Shackle hanger bolt
Camar068
10 yrs Air Force
86 K10 stock. I'm going to have the bushings changed on the front leaf spring rear shackle hangers and leaf spring bushings. The bolt currently is installed from the inside out. My exhaust pipes are right there blocking it from being able to pull it out easily.
Once the old one is hacked out, is it ok to install the new bolt from the outside in, with the nut closest to the exhaust....instead of the bolt head? I'd assume so, thought I'd ask.
77 K20
Montana
K20 5" lift
HT383 fuel injected
That is what I did years ago and haven't had any issues.
Camar068
10 yrs Air Force
sweet, thanks a bunch
idahovette
Weiser Idaho
Perry
K20-K10
If it's the bottom bolt ,you could remove the top bolt and let the spring down to remove the bottom bolt?
Camar068
10 yrs Air Force
right, but it's the top
idahovette
Weiser Idaho
Perry
K20-K10
OK,Damn. Fire up the sawzall or the torch!
Camar068
10 yrs Air Force
Is it really this easy? Skip to 1:55. There isn't an outer sleeve to cut out? Was getting ready to pay someone $200 cuz I thought you had to chisel out an outter sleeve. These were the only bushings I didn't replace ~2 years ago.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Do you have a photo of the front shackle? I am in the process of getting ready to remove a ****** lift from my 86 CUCV. I'm interested to see how the OEM shackle looks compared to these homemade looking shackles.
hoagster
California
K10, 1500
5.3l
it's not that hard, to change the bushings. I know I had everything removed body, engine etc. when I did mine. Use a C-clamp to press them in and liberally apply the lube they supply for the bushings. Not to advertise but if I was to do it over again I would get the ORD version of rear shackles with the greasable bolts.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Them bushinga can be a real PIA.
I use a balljoint press and push them out, but I have seen people torch the rubber out, which in turn removes the sleeve in the center, then take a air hammer and knock out the outer sleeve of the bushing from the seam that makes the leaf springs "eye"
Dutch Rutter
Independence, Or
Joshua
One thing to keep in mind if going with the ORD shackles. They are longer then the OEM shackles by 1/2 inch or so. They are a great piece. I have them and really like that piece of mind and extra movement.
Craig 85
Nashville, TN
454/TH-400/NP205
I have ORD's in my K30. As you can see from the prior post, they are way beefier and are grease-able. My original upper bushing had an oval shaped hole due to wear.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
What is the distance from hole-to-hole on the ORD design? Mine have some adjustability but not enough to get to stock ride height.
Dutch Rutter
Independence, Or
Joshua
1/2 inch longer then stock. (I corrected my post above) no where near those home made jobbers. I can measure after work, unless someone beats me to it.
Craig 85
Nashville, TN
454/TH-400/NP205
4.5".
My only worry with your step up is the possible side to side flex. It looks like your bushing is not centered in the spring.
What's the Caster set at? It probably will return the steering to center well.
MixManSC
