Old60Driver
1983 K20 Silverado
- May 17, 2020
- Houston
- Michael
- K20 Silverado
Those would be the already upgraded heads.
I would check to be 100% sure, a quick call to Summit should find out what you want to know.
Thanks for the advice! I actually made the call this weekend and talked to Summit. A fella there assured me that the heads would work as is. Thanks again for the reassurance!
If you just hate the Quadrajet, assuming it still has it, go Holley.
To be honest, I didn't know what a QJ was! I mean, I had HEARD of them, and how some folks hated them, but due to your post, I've delved DEEP into QJ history and performance. Personally, I love the idea of vacuum controlled secondaries. It seems that if I rebuild the Quadrajet correctly, AND get it tuned, it will adjust my CFM based on engine need. No worries with 'over carbing', right?
I don't really have much in the way of an update, as I don't have her in my possession as of yet. I've been doing a ton of research in preparation though!
So here's my first week's plan:
- Get her home
- Change fluids (oil, coolant, brake, trans, diff, transfer)
- Perform leak down
- Change (and inspect) plugs
- Desmog (TBH, I don't really know what she has in this department though...)
- Rebuild QJ
- Replace dizzy and wires
Thanks again for your replies, again, sorry for the late response from me. Thirteen hour nights just suck. Especially when I'm old enough to need to a bunch of 'ologists' on speed dial. Cardiologist. Urologist. Endocrinologist. Ophthalmologist... Well, you get the point.
Stay safe y'all!
