‘77 C10 12 bolt to 14 bolt conversion
Rich77
SE Wisconsin
Rich
C10 Scottsdale
Hi guys,
it seems like it might make sense to change out my rear end.
How much different is a 14 bolt full floating axle with 3.73 gears and posi (which is gt4 g80 axle code) compared to my C10 12 bolt?
The 14 bolt is out of a 1989 GMC suburban c20 3/4 ton 2 wheel drive.
Is it a drop in fit? Are the leaf spring saddles and shock mounts in the same location?
Is there a drawing comparing them?
I searched with no luck.
thanks!
Customblue
Locust Grove, Va
Brandon
The FF will be a direct swap but the driveshaft will need to be shortened if I am correct. At least it works like that on the k series
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
The u joint may also be a different size. You can get a hybrid u joint to accommodate both size yokes or have the drive shaft yoke changed if the driveshaft needs to be shortened.
Craig 85
Nashville, TN
454/TH-400/NP205
What are you looking to do? You will need 8 lug wheels new U-bolts and spring plates, etc. I know in the 88 and up trucks (new body style), did offer a 14 bolt semi float with 5 and 6 lug options. I believe the spring perches are different. The 454SS pick ups had them in a 5 lug set up.
RNFL
