Yeah, the oil pressure switch performs two functions.
1. At start-up it is designed to apply battery voltage to the choke heater coil as soon as the engine is running. There may be a momentary lag - until oil pressure is established (around 10 psi).
2. When the engine is shut off (and oil pressure drops to 0 psi), the switch opens and power to the heater coil is secured. This is helpful because, if for some reason, the ignition switch needs to be left in the RUN position while the engine is off, the choke heater won't restrict the closing motion of the plates.
If your engine still has the oil pressure switch (two terminals) and the oil pressure sender (single terminal) run a keyed power source to one side of the
switch. The
sender (bell shaped) is for gauge operation only and is unrelated to the choke heater circuit:
Also run a lead from the other terminal over to your carb's choke heater. The image below shows that lead connected to a Q-jet. Q-jets are self grounding through the carburetor housing so no ground lead is needed, but some after market carbs will require an external ground wire:
