Repainting my 1980 Custom deluxe
Jt1776
ROCHESTER HILLS MI
Custom deluxe
I'm getting ready to paint my truck. Do I need to prime it ,and what type of primer to use. I'm not looking for a show quality paint job. This is my first time I'm painting a truck. I spray my furniture I make so I'm familiar with a sprayer. What are the proper way to to prep and paint. Do I put a sealer on before or after I prime. Last question where can I find the paint code for my truck. Thanks jerry from the motor city
There's LOTS of variables that determine what you need to do before paint. What finish is on the truck right now and what is the condition of it? Are you going to fix any dents or rust?
Jt1776
ROCHESTER HILLS MI
Custom deluxe
I fixed all the rust as best you can do without cutting pieces. It's in really good shape, it's about 90% rust free. I'm not really restoring it. This is just my work truck. But as I go I'm wanting a better job. Here is a couple of pictures. Thanks
80BrownK10
Greenwood, SC
Nate
Just prime bare metal or bondo work you have done. Roughed up all the existing paint good to give it a place to adhere to, then shoot it with paint. If you do base clear paint you will put a few coats of color down then lay the clear down. If you go single stage paint you just put several coats of paint down.
Jt1776
ROCHESTER HILLS MI
Custom deluxe
I bought a qaurt of Por 15. I was going to spray that over my problem spots. I'm not trusting I got all the rust.i thought I had to prime over the old paint. Thanks
If you have sanded the paint with coarse grit sandpaper, you will want to prime those areas as well. The type of paint you are using will determine how coarse is too coarse.
Poppy 87
Bloomingdale GA
R10 Silverado
Read the application instructions carefully prior to spraying the por 15. Dwell time and temperature is critical before top coating
Jt1776
ROCHESTER HILLS MI
Custom deluxe
I sanded it with 220 sandpaper, and it the feels really smooth. If I don't need to prime it that saves me money and time. Now I'm having a hard time finding my paint color. I have went to numurist websites and can't find my color. There is no color for Camel Metallic. Thanks for all the help from everyone.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Nice dog
Your paint color codes are 65 for the primary color and 60 for the secondary. This site has both colors,https://www.automotivetouchup.com/touch-up-paint/gmc/1979/all-models/ one shows up as "Camel Metallic" and the other as "Neutral". There are often other numbers associated with these old paint codes. You'll see on this site it links your color code 65 to 8058 or WA8058. If you take those codes into an automotive paint shop in your area, they should be able to give you the right color.
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
How did a Michigan truck avoid getting super rusty?
Jt1776
ROCHESTER HILLS MI
Custom deluxe
The truck is from hickory NC. It only has 118000 miles. And thanks for the paint codes. Plus my 2 blue heelers say hi
Jt1776
ROCHESTER HILLS MI
Custom deluxe
Great looking Truck. It must be a late 1980 I see the square headlights. Mine is a early 1980 model it was the last year for round headlights. It should be painted as soon as the paint Store opens. I will seen some pictures.. Thanks
dhenderz
Michigan
Dennis
For what you're trying to accomplish here is my advice. I would spray the entire truck with a primer/sealer like Southern Polyurethane's epoxy primer (with reducer to thin it to be a sealer - call them for a copy of their tech manual). Choose the SPI epoxy color to best align with the final color you plan to choose. In this case I would probably choose gray.
Then I would simply spray it with single-stage urethane paint. For what you are trying to accomplish there is absolutely no reason to spend the money on base/clear. It will cost you twice the money. For the paint I would either go with Summit or Eastwood. I have used both for quick, low-cost resprays and they work fine. For that matter you could probably also grab the primer/sealer from either Summit or Eastwood. I am generally using SPI these days, but the others will be fine as well.
The reason you want to spray the entire truck with sealer (1 coat is all you need), is to achieve a uniform color and holdout as your base. Otherwise it will take more paint (ie: more coats) to achieve a uniform color match with your actual paint. Paint does not have the pigmentation now like it used to. For that reason it does a poorer job of covering disparities in base color.
TheDuke
