Gauges and dash lights won’t work
Pappy Parker
Pennsylvania
Hello. My 1980 k10 fuel gauge and dash lights don’t work when I turn on my parking and head lights. I’ve replaced the headlight switch and the dimmer switch, the only difference is now the high beam indicator is backwards.
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
Sounds like a bad ground under the dash near the Parking Brake pedal.
Hi Snoots,,,I know this is an old thread, but, I am having similar issues and another member here has told me the same thing regarding bad ground,,,,,,I have looked under the dash and can't find this mystery grounding point by the parking brake pedal,,,,,what am I missing???????
Hmmm. Good question. They didn't really change much until '92.
It may be higher on the kick panel. Mine was kinda hidden behind the side of the Parking Brake.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Check higher up toward the windshield. Mine was easily accessible when I removed the gauge panel for other maintenance.
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
Thank you Sir, this helps , at least now I know what to look for
garethrowsell
