Hard to shift into and out of 4 wheel drive
Scottserado
Aidan
Hey everybody I need help figuring out why my 85 k10 is hard to shift into 4 wheel drive it’s a bit hard to do I think my transfer case is on its last leg and might replace it it’s a cast iron one is all in know.
WebMonkey
Missouri Ozarks
1985 should be aluminum except k30.
anyway, even if you fill up the case with the proper fluid, this could happen.
my case was super duper hard to shift from 4wd to N to 4lo.
then it died.
that's my 'flying turd', so be careful and get that case some lovin'.
Scottserado
Aidan
I just got the truck November as a project and the owners trashed the thing no transmission fluid so I’d say it might need a new one.
RoryH19
Rory
R10 Silverado SWB
then it died.
I had a 86 k20, same t-case NP208. I've bottomed out, even with a lift, several times and only cracked the case. Partial skid plate doesn't cover all.
I've never blown one up before.
RoryH19
Rory
R10 Silverado SWB
You will have the lighter duty 27 spline NP208 since it's a k10, unless it was changed sometime.
Do you have a TH350 trans?
Scottserado
Aidan
I’m not sure what trans that would be but what I have is a 3 speed column with 4 wheel drive no overdrive
rumpity_z28
