- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
So it's not for my truck, I have 4wd, that needs rear tires. Bulge in sidewall and dry rotted(2011 tires). The fronts were replaced with passenger highway tread tires from Walmart(they work perfectly fine) but the back needs new tread. I am not putting the same ones on because I use the truck often enough with heavy loads or trailers. In addition, I also need something more than HT because unweighed the thing can't get out of it's own way currently. So 6 or 8 ply minimum and it's gonna need tread. I understand more tread and ply means rougher and louder, but it's a work truck first and foremost. Not a daily.
Winter use is minimal, so not looking for a snow tire.
Assuming the tire is made in my size(15 inch, exact unimportant), what's a good tire line?
I was thinking Cooper AT3, Bf Goodrich KO2(although a little aggressive), Goodyear Wrangler SRA, and I forgot tire name but one made by Hanook.
No limited slip, one wheel parking brake(allows forced traction on one side if wanted). 1/2 ton truck.
Ideas?
Ideas?
