turbomatt
- Sep 26, 2017
- norwood co
- matt
- suburban
Howdy knowledgeable masses.. hows this for puzzling.. lights on my 79 suburban were replaced recently with high output jobs.. maybe 5 hours of nighttime driving on them. Driving home other eve and noticed drivers side out high and low beam. Trusty voltmeter shows just under 11v on both sides with engine off so I buy a new light. Plug it in. ..almost immediately the low beam pops, switch it to high beam and within 20 seconds, the high beam fails... this is with the engine off and showing 11v on the meter... never seen where <12v would make a filament fail , let alone both within a few seconds.. harness runs from pass side which is fine and ground seems fine... any ideas?
