nabeshin
functioning lunatic
- Jan 23, 2020
- Cozad, Nebraska
- Grae
- K10
Tried to do a bit of search here but didn't come up with much.
I noticed my fuel pump is leaking; squirts of fuel out the back end of the flying saucer part at the seam towards the manifold. I was checking to see if I had fixed an exhaust leak after tightening the manifold down pipe nuts when I saw this.
Exhaust is fine now, but I need a new pump. It was replaced at some point, it is not original, but seems to be an AC Delco unit. It has two outputs, one to carb, and one to return to tank. Summit is a little light on replacements with a return, can i cap the return and just use a pump with one outlet to the carb?
