K10 front calipers don't fit back on with new pads
Spalding
Tx
Nate
350 smallblock
I have a 85 Chevy K10 I recently put new brake pads in the calipers but now the calipers will not fit back onto the rotor anybody had this problem I got them on but they are so tight that they don't allow the wheel to spin
1973c10
Don
Welcome aboard
did you push the piston all the way in
will they turn with the wheel on
Spalding
Tx
Nate
350 smallblock
Yes I even bought new calipers just to see if it's something with the old ones but same problem the wheel will turn they are so tight the roter gets hot and smokes
waynew
Rocheport MO
Wayne
K1500
Vortec 327
I had this exact same problem, new calipers and pads too. I ended up taking the grinder to the pads to remove a little material. Problem solved. The only other thing I could think of doing was to shop for different pads that were a little thinner.
SirRobyn0
Rob
Well I have run into this at shop before. Is there any possibility you got the wrong pads? Could it already have had the incorrect rotors from a previous install. If u have a way to measure the thickness of the brake rotors start with that. Take that reading to the parts house and tell them what the problem and ask them to bring out any optional pad types, rotors, or calipers. There are only 4 possibilities, pad problem, caliper problem, rotor problem or no offence an installation error. Is this happening on both sides or just on one side?
Spalding
Tx
Nate
350 smallblock
I thought about grinding them but didn't know if I was just going to ruin the new pads thanks I will take a grinder to them this weekend .
Spalding
Tx
Nate
350 smallblock
It is happening on both sides
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Did the new calipers fit even slightly better when you first installed them? If so, it might be worth getting new flexible brake hoses. Bad hoses can act as a check valve or a plug and make any caliper piston either extend and stay that way or have serious issues when you go to retract the piston(s).
Still the same rotors as before? 1.25" thick?
Could they be the incorrect calipers? C10's with light duty brakes have 1" thick rotors. The calipers look and bolt up the same as the calipers for 1.25" rotors, just slightly wider obviously.
Spalding
Tx
Nate
350 smallblock
I got new calipers same problem as old ones I'm thinking the owner before me could have maybe put wrong roters
bedwards
Adger, Al.
Bryan
c10 Silverado
I had a set on another vehicle that I had to run through a milling machine to get them to fit.
Chinesium
SirRobyn0
Rob
Whatever you do I'd strongly discourage grinding them. Think about this, if you grind the pads, how are you going to get them perfectly flat and level, and unevenness will adversely affect braking possibly to the point of being dangerous. Plus what you'll breath in during the process even if they are asbestos free there's all kinds of heavy metals that are terrible for you to inhale. I've been a mechanic for nearly 25 years and I've never once ground brake pads or machined rotors to make them fit. Remember your safety and the people around you depend on your brakes functioning as they should. Someone else mentioned two different rotor thicknesses, and you say you have the thinker rotors, perhaps that's the issue. If you don't want to talk to the people in the parts store, look it up online at the parts company of your choice.
Spalding
Tx
Nate
350 smallblock
I'm not going to grind them I put the old brakes back in for now going to look into the calipers
Spalding
Tx
Nate
350 smallblock
kmousseau8
