- Jul 22, 2014
- usa
- carid
- K30
- 4.6 L
Just recently, Lumen® released its newest version of the LED tailgate light bar for mid- and full-size pickup trucks. It features three rows of ultra-bright LEDs (1000 for 48’’ bar and 1200 for 60’’ version). The accessory works in conjunction with your stock tail lights featuring running and brake light, sequential 3-stage turn signals and hazards, and reverse light. With such a lightbar snugly fitting the recess between your tailgate and rear bumper, you will never remain unnoticed by distracted drivers, which means your driving will become safer.
Now, when going in reverse, you will see much better, and your reverse camera view will benefit as well. The accessory has a sturdy aluminum construction that can be attached to the back of your truck using a strong 3M adhesive. The same two-sided tape is used by automakers for installing exterior trim components and emblems, so you can be sure that your light bar will stay in place no matter how harsh weather conditions and driving situations might be.
Lumen® - LED Tailgate Light Bar
Specifications:
Number of LEDs: 48” light bar – 1000, 60” light bar - 1200
Housing material: aluminum
Can be cut: no
Plug: 4-pin flat connector
Warranty: 1 year
Features:
Dazzling LED Sequential Turn Signal Display
Super Bright Reverse Lights
Weatherproof construction for reliable operation (IP67 ingress protection rating)
Dependable operation in any weather conditions (Working temperature range: -20°F to 170°F)
Easy Plug-and-Play Installation
If you have any questions, feel free to ask them in replies or in private messages.
Also, you can contact our technical experts in Live Chat at CARiD.com or simply call 800-505-3274 (tall free).
Specifications:
Can be cut: no
Warranty: 1 year
Features:
