- Feb 28, 2017
- Central IL
- Quincy
- K30
What is the real purpose for this rod, does it work? I had help with my swap and the person swore til he was blue in the face that it was the worst idea to come out of GM in the last 100 years.
It ties the transfer case to the transmission and the transmission to the engine mounts. This is also assuming that you have all the pieces. High torque and stresses break transmission bellhousings (among other components) and these pieces when all there keep that from happening. I've seen it happen and i'll swear until i'm blue in the face that they are an absolute must if you're making any kind of power or doing any sort of high stress work/pulling. But I will add that all the mounts need to be in good shape is well. And if you replace one set of mounts, you want to change them all. Don't put new motor mounts on and leave old/worn out transmission mounts and vice versa.
