Wumbo
- Dec 12, 2018
- Illinois
- Rob
- C20
Engine was stock 454. 50k miles on it. Changed cam, heads, intake, gaskets and seals.
Pulled rear bearing cap to change rear main seal. Bearing looked perfect. Reinstalled and torqued cap per factory service manual.
Bottom end is fairly tight without valve train, takes about 40 ft lbs to turn.
Cam rotates with no effort when valve train is unloaded.
Setting lifter preload (hydraulic) on intake side doesn't affect the amount of torque to turn crank by much.
When I get to #6 on the exhaust side, it gets real hard to turn the engine.
Heads are 049 ovals. New guides and valve job. New Melling valves, Viton seals, COMP springs, locks and retainers to match cam.
Assembly lube on everything. Valves moved freely during head assembly.
Next step is to pull the viton seals off the exhaust valves and replace with umbrella seals.
Looking for a sanity check.
