Is this on purpose or wrong part???
Westislander
Massachusetts
Gregg
I am installing the rear end on my k10 today. It has a new Rough Country 4in lift (block) kit that came with new u bolts. I didn’t notice that 1 u bolt is a solid inch shorter than the other 3. Did they send me a wrong part? I can’t think why 1 would be shorter. I checked and all the front ones are the same, about 9 inches. The 3 rears are about 12 inches and the oddball 1 is about 11 inches. Everything is seated where it’s supposed to be, It has to be a wrong part
1985c20
Torrington, CT
Chuck
If you have enough threads to stick out of the end of the nut you are fine. So I was going to say it’s fine but then I looked closer and it looks like you can see light around the u bolt at the axle indicating it’s bent for the wrong diameter tube which is no good. Looks like they got it mixed up with one for another application. I’d give them a call.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
You want at least 1 full thread past the nut for the lock nut to work properly. Yours looks very borderline. I’d swap it...
Westislander
Massachusetts
Gregg
...So I was going to say it’s fine but then I looked closer and it looks like you can see light around the u bolt at the axle indicating it’s bent for the wrong diameter tube which is no good. Looks like they got it mixed up with one for another application. I’d give them a call.
Chuck, I hadn’t even noticed... I went back and checked, the u-bolt is definitely too wide, I’ll call them in the morning
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
If it was for a larger tube, you would have had to squeeze it together
to fit in the holes of the top bracket.
Yet you say "Everything is seated where it’s supposed to be".
I dunno...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I dunno...
I thought it might have been an optical illusion but the OP says it is in fact too big... yeah hmm..wdf
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Are we witnessing a Mandala Effect in real time?
nvrenuf
Mobile, Al.
It looks long but is that the big u-bolt for the front?
MikeB
Justin, TX
Good catch!
eskimomann209
Modesto
Marcus
That looks like a reflection in the paint to me...
Isn’t there a flange right there like a track for the u bolt?
I think it’s the reflection off that...
But I cut my perches off a looong time ago...
so I have nothing to compare to...
So it could be wide
Westislander
Massachusetts
Gregg
I dunno...
This did happen, it wasn’t much but I did squeeze it.... definitely the wrong u bolt. I called Rough Country and they are sending me out a replacement
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
Good deal!
mitchell1128
