Bench seat bolt problems
Michael Wood
Payson, AZ.
Michael
R30
350 cid. / 5.7L
The 2 front bolts on my bench seat came out and are pretty messed up (stripped threads).
I was going to just drill out the holes enough to get 2 3/8" bolts through the holes and put washers and nuts on the underside of the truck and tighten them down..........
Any better idea's from any of you seat guru's??
Or will my fix be good/safe enough.
I could just weld the seat bracket to the floor but I may want to take the seat out again someday.
eskimomann209
Modesto
Marcus
Problem with your idea is gas tanks in the way on one or both sides
73c20jim
Tombstone, AZ
helicoil or drill and tap oversize???>
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
With a one ton frame you should have enough clearance for longer bolts and nuts.
I have a couple inches between the body and tanks on my k30.
Michael Wood
Payson, AZ.
Michael
R30
350 cid. / 5.7L
I guess I will run a tap through them if I can clean them up and if not I will drill & re-tap to a larger size.
Is it common for these bolts to come out? I had one laying on the floor and one just barely in.....
crpntr78
Missouri
Not really, more apt to break them off while trying to take them out.
After you re-thread the holes, I'd coat the new bolts with anti-seize.
manther
