climb-101
montana
seth
c2 crew cab
6.0 LS
Nice, I wish I had cash, space and time to learn working a lathe. Great for making custom transmission drums. I'd also like to make a set up bushing drivers.
i love my lathe. i use it all the time, don’t know how i got buy without it
82Diesel
USA
6.2L
Nothing lately... had a small spring snow shower here then back to rain and mid-40s - 50s.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I've got two axles that have me in the same boat. The drums are STUCK. One is my axle that's been sitting out in the weather for several years, which is understandable. But the other is under my Burb that has only been sitting in that one spot for maybe 6 months. I was swinging the BFH at them with all I got and they are still stuck. I'll probably have to cut them.
Well your kind of a midget so yeah
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Started it twice yesterday and let it run to operating temp.
Had a garden lizard under the hood in the plastic vent cover and a green frog inside the passenger door so I know it is being guarded while I am away.:D
Before
After
Waiting to come across another “real” GMC grille to fix Bucket’s contribution to the cause, but until then.... I like it.
What do you guys think?
GMC emblem in a plain Chevy grille, that's actually a really good idea.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I put my push bar on today. I also discovered my third broken sway bar mount. I’m going to just take it off until I can make something that will hold up.
fmxr47
US
Justin
I started reworking my flat bed I got in a trade a few years ago
I narrowed it down to 80”, cut off the headboard to remake, cut off the stake pockets on the rear as well. Now to clean up the edges and determine what material I want to cap the sides with. I may be angling the back of the bed from the edges into the frame width.
eskimomann209
Modesto
Marcus
I let the beat drop
bigcountry78
James
K10 Custom Deluxe
I took my sway bar off today. I was going to try to see if I could make a bracket that would hold up better, but I think I’m going to drive it for a while and see how it does. I may just end up leaving it off.
CoggedBelt75
Altus, Oklahoma
Joe
I’ve been without one going on 18 years. It may “feel” a bit different cornering at speed tho. You’ll being losing some body roll control. Guess I’m just used to it. Mine’s off to help with launches on straightaways.
Changed the oil in the dually and drove the '77 a little bit.
With power steering the body roll will be more noticeable. With manual steering it's difficult to turn fast enough to cause body roll.
Fixed some vacuum leaks that were causing bad issues.
texdave
