idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
So, the more is better theory does not apply here?
Were you dropped on your head as a child?It's not rocket science..two things kill oil
Heat and dirt.if you race or do hard use.or you do not change the filter.say every two thousand miles.
You notice the vehicle still comes with just one engine filter.not two or three.they want the engines to go out.
Because of oil.kill the warenty.in the old days we used 10/40.some people.the old guys.used 30 weight.big block engines
As the people got dumer and more complained about lifter noise.on cold winter mornings
They switched to 5/30 ..the engines.the last place to get oil.is the heads.oil gets hot.some burns.and it gets in to your filter
When they changed the engine design up.years ago.they went from pressure too volume.
Flow.i went to look at a car one time.for sale.it was making a noise.engine was gone.the stupid man said.i don't know why it's doing that
I used. Snythic.like royal purple or something.i just laughed.all oil and filter has to be changed.
No matter what the oil.or what you pay for it.all those oil change places.use recycled oil.as far as I know.its cleaned and additives are added back to the oil
I like 10/40 and even 20/50 .good oil if you run a strong.horse power engine.that lukcus oil treatment
Sounds Sood.but have not used it.
Use this REAL additive and you can use any off the shelf oil you'd like,
https://www.amazon.com/dp/B002C6E0V...olid=1READJHQJE4XJ&psc=0&ref_=lv_ov_lig_dp_it
I like to add a tiny bit of Moly, but you'd only want/& need a very small amount of zinc to be present.
The lubrication technology this is made from has been proven, and you can even drop down to a lighter viscosity and still have greater film strength.
