83 K10 Quad Shock Removal
Blake
South Dakota
Blake
I've seen a few guys talking about this but i want to be clear before I start working on my truck. I have factory quad shocks with stock suspension but I'm putting the 6in rough country lift on it and have heard that the quad shocks make it ride rough so I would like to just run single shocks. Wonder which shocks I need to take off and if it's worth it or not.
I had the standard shock setup on my Burb. When I installed a factory quad shock setup, the ride stayed the same.
The "additional" shock mounting for the quad shock setup is a more effective location compared to the "regular" shock location.
Rusty Nail
Rusty
350sbc
Installing a "Rough Country" lift and you're concerned about it "riding rough"? I've got news for ya...
I will NEVER believe that removing shock absorbers will improve ride quality. That is a completely absurd notion no matter how you cut it.
PLUS it will devalue your truck even further than a 6 inch lift ESPECIALLY a crappy, cheap one like rough country.
That's all.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Blake
South Dakota
Blake
D
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
I'm not concerned about it "riding rough". I was simply asking if it would "improve" the rough ride...not get rid of it. And as for devaluing my truck....I I got the truck for free from someone that was going to have it crushed..pulled the trash 305 out and put a 454 that I built to with a tbh350 with performance shift kit in and and I'm building the truck how I like it...so as for you saying its "devaluing" my truck....I dont think you can devalue a truck you paid ZERO dollars for....but I appreciate the advise sir. I will not remove the quad shocks...have a nice day.
That wasn't me that posted that. I only posted the welcome.
Blake
South Dakota
Blake
Must have pushed the wrong button. Sorry
One flaw to the quad shocks is the added stress to the lower mount on the axle. Many people have had the mount crack. I've put a lot of miles and hard use on mine and they are still fine.
RoryH19
Rory
R10 Silverado SWB
I have the quad shock design on mine but the previous owner removed when the lift kit was added. Was looking at changing all shocks and springs to a 4" lift. Rear has blocks at the moment.
Any reviews on the rough country or pro comp setup? Should I also put the quads back on?
Customblue
Locust Grove, Va
Brandon
When I put new shocks on my mine truck I went with skyjacker hydros. Rides alright considering 4 leaves up front and 7 in the rear
RoryH19
Rory
R10 Silverado SWB
I saw those on ebay, about the same price as the pro comp ones.
Not sure how many leaves are in the kit. Not sure if the pic is accurate.
Customblue
Locust Grove, Va
Brandon
I can't remember where I bought my springs but I got the HD front and rear. The rear is fine but I wish I would have gone with the 3 leaves up front. 4 makes for a rough ride but hell, it is a truck. The hydro vs. Nitro makes the ride so much better/smoother
RoryH19
Rory
R10 Silverado SWB
Right, I saw standard and HD springs while looking. Probably just use standard ones. Either way it won't be like riding in a Caddy.
iiixtremeiii
