Let's say I got a C-30 but NEED to have a 4x4...
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
If i had more money and time i would buy one of those and remove that dump body. Then i would cut the front off my junk Suburban right at the top of the windshield and splice it together making a Suburban limousine.
Big Chip
Michigan
Kevin
C35
I'd love to get the numbers for those trucks. It sounds like what I need for my business. Used to drive an 84 with a 12' stake bed, diesel with a 4 speed. That truck could pull anything!
Big Chip
Michigan
Kevin
C35
Except a hill at 65 lol
It wouldn't hit 65 on the downhill with a stiff tailwind. It was more of a city truck in that respect. At 60 it sounded like engine parts were on the verge of coming through the hood.
roundhouse
atlanta ga
justin
77,78,79,80 ?
There’s still some good crew cab 4wd K-20s our tuere
You just have to widen your search
If you use CL click on “search nearby areas “ and refresh the page
Then click on search nearby areas again and it will give you 40 more towns to include
Click em all and refresh again
If you get out a map you can quickly figure out which towns in which states you need to put as the starting point to cover as wide an area as possible
As an example , Montgomery Alabama will cover most of the south if you click the nearby cities twice to load up as many as it will let you
Then you have to search for
K 20
K-20
c20 etc
Or search for
1974 crewcab Chevy
1974 crew cab Chevy
1974 crewcab Chevrolet
Etc
Some 4 wds will be listed as a c20
C10 Or whatever
I’m in Georgia and we found the truck we were looking for in AZ for $1,600
Rust free 4x4 Stepside with a manual transmission
Transport was $800
Totally worth it for getting a rust free truck
The ones in the southwest and California don’t cost any more than he trucks everywhere else
And most have very little or no rust
Just gotta fly out and look it over , buy it , and either drive it back , tow it back , or put it in storage and arrange transport
Or have a trusted person look at it
We had a friend of a friend look at it and transport it to us
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
In all due respect guys, some of you really need to learn to use the search features.
Having said that I will still help.
The answer is ... no, no, no and no.
2 wheel drive trucks do NOT have the same frame as 4x4. It is not the task of bolting up 4x4 brackets. The upward sweep of the frame, to give clearance for the front axle (4x4) or a place to mount the upper A frames (2x) is different on the two models. Yes they look the same but under careful examination you will discover the differences.
Using a B52 kit from DIY4x4 will work wonders to convert a 2x to 4x.
I wouldn't hesitate to buy that monster dump crew cab, and shorten the frame by moving the spring perches forward (if you want a small lift) and chop off the frame left behind. Use shackle flips to lift the rear.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
K 20
K-20
c20 etc
Or search for
1974 crewcab Chevy
1974 crew cab Chevy
Etc
C10 Or whatever
The 20 series is 3/4 ton. All crew cabs are one ton.
The 30 series is one ton, C (2x) or K(4x). Then they switched to V in the late 80s... which leaves me confused a bit.
Mike7ftr
Fresno
R30
Soooo long! This baby is needing some love. Hopefully this winter I'll have some time.
roundhouse
atlanta ga
justin
77,78,79,80 ?
Yeah but I’ve seen crew cabs that don’t have the dual wheels in the back so that means they are 3/4 ton right ?
It’s very confusing and most CL posters can’t even spell Camaro
So after you search for K30
Then you need to search for “K20 crew” etc
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
One tons also come with standard rear wheels. It's the weight capacity that makes it one on, not the dually rear end. You can rest assured, all dually squares are one tons... unless of course somebody changed things up.
I have seen (only once I believe) a 4x4 crew cab with the GM 12 bolt front diff and I thought it was a 3/4 ton... but no it must have been swapped out. As far as we know, all crew cabs are one tons.
Most CL posters don't even reply to add queries...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
21' long from bumper thingys to rear bumper!
willyg
