Daveo91Burb
- Jul 6, 2014
- Vancouver, WA
- Dave
- V2500 Silverado Suburban
- Vortec 383, modified TBI/4L80e
My direct drive Delco (early 70's vintage, I believe, with a cast iron nose) is working fine about 90% of the time. The other 10% I get nothing at all, I don't think I'm even getting a solenoid click. At first I thought I was getting solenoid click, but I think I'm hearing my aux battery relay, i.e. when I turn starter switch to run, relay is triggered to connect the two batteries, but when I go all the way to start, I think it clicks again to disconnect them. (Let me know if I'm wrong here) Anyway last time it happened I had to cycle key to start about five times and then it started fine. When it was happening, radio, wipers, headlights, etc. worked fine and headlights did NOT dim at all when I turned key to start. Weird thing is it's happening much more often when it's wet out: it's happened when it sat out in the rain for a couple hours, and another time just after I had washed the rig.
Things I'm considering:
Solenoid (actually picking one up tomorrow - they're cheap)
Ignition switch
Key switch/lock cylinder
Starter trigger (purple) wire
Other things to consider?
Ignition switch
