Best budget V8 swap into a 1986 C10?
Ohio
Mark
5.3L
There are some hidden costs swapping the 5.3LS motor in but the advantages are worth it. I also put a posi and 3.73 gears in . What a blast to drive.
DixieScottsdale
VA
Zan
4.3L V6
Are you running A/C with your swap? My truck has factory A/C, and I'm wondering if there's a way that I could adapt it to work with the LS accessory drive.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I used the LS A/C compressor with my stock Squarebody A/C. You can also modify a TBI R4 compressor bracket to work on the LS, or user an aftermarket high mount A/C kit. Lots of options.
Ohio
Mark
5.3L
I bought an adapter for the stock AC compressor that clears the frame, and I will make my own AC lines.
NarwhaleAu
Houston
Phil
350ci Chevrolet
You and I will be swapping at about the same time. :) Good luck sir!
Camar068
10 yrs Air Force
You can also modify a TBI R4 compressor bracket to work on the LS.
Is that using the bracket and the LS compressor or the old compressor.
Thx M8
GrayWK
