GreaseDog
- Aug 8, 2010
- Elkhart, IN
- Jeremy
- 1977 K20
- 1980 K2500
Got an 84 C10 that I'm planning on swapping onto a 4x4 chassis, I'll be using a 94 K3500 TBI harness to swap in the 80e. Originally transfer case in the donor had a VSS on the output shaft, this won't work with the stock speedo add it is cable driven. I've read somewhere before that you could use the VSS built into the back of the speedo to feed the PCM the VSS signal it will be looking for. Does anyone know how to go about doing this?
