The wiper arm for a 1984 CK 1,2,3 was only used for that year. The part number for the wiper arm prior to that (81 -83) was 14032715. After 1984 (85 -91) the part number was 15522766.
I can't tell you what the difference is - I'm not familiar with the wipers on a 84. But it probably has something to do with the washer nozzles. Before 84 the nozzles were located under the cowling and sprayed up onto the windshield in just one spot. Later models had the nozzles built into the tips of the arms - so the washer fluid was sprayed over a larger area as the wiper arms stroked back/forth.
Or it may be something else, like the spline count on the drive pinion for example.
Anyway, any arm from 81 -83 will fit your truck.
