Vent window gasket placement?
Josh Barnett
Colorado Springs, CO
Josh
On 91 suburban doors do the vent window gaskets sit on the outside or are they tucked in? Didn't pay attention when pulled out.
The lower leg and the hypotenuse wrap around both side of the frame and are visible from inside and outside. The vertical leg - the one where the lock handle is mounted - is kind of tucked into the frame on the outside and is not visible from in the cab. So, from what I can see, you have it right.
Submariner592
Wisconsin
Scott
C20 Custom Deluxe
Very nice job, as said before looks correct. I tried mine 2 times (failed huge) and finally sent it to a guy in CO to do it for me. ($ ouch)
MikeB
North Texas
Very tough job. Took me many hours and lots of sweat to get the fit right. Used both ends of plastic putty knives and lots of soapy water to coax the rubber into the frame. My fingers were sore when I was done!
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
They should tuck into the door frame like so:
Josh Barnett
Josh
thank you, I think I got them right...
Oldrider
NC
k2500
I have a dumb question, are you doing this with the vent installed on the door or removing the vent window?
Josh Barnett
Josh
The vent is inside the door but not fully seated yet, then I pushed the gasket in as I worked the vent back into place.
kmousseau8
