Temperature and Oil pressure guages
Pineywoodsbow
Jason
I need a little education on how this works on my 85. I want to get the original guages working(right now an aftermarket guage for oil,temperature, and voltage is installed). I pulled the instrument cluster to see how I might go about this and noticed the printed circuit board, no connections for the temp line or oil pressure line. How would I go about reinstalling these guages?
MikeB
North Texas
So you have the original gauges in the dash, but they are disconnected? Or does the truck have idiot lights?
Pineywoodsbow
Jason
Yes the original gauges are in the dash, but I'm guessing they are disconnected because the new aftermarket gauges are being used which are in a different location. I just don't understand this printed circuit board thing. How would I get these working again?
4WDKC
Southern Florida
Kacy
sounds like the connections from the sending units to the original gauges have been replaced by the after market gauge sending units. Look around for loose wires under the hood.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Coolant temp should be green and oil pressure should be brown.
Pineywoodsbow
Jason
Thankyou! Could I just splice the original wires under the hood to the new aftermarket sending units?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
GM and after market temp sensors run at a different resistance value so if your installing a proper sender I'd run new wiring. Or use mechanical gauges.
rt66paul
California
paul
1991 suburban
Someone replaced the stock guages. I would guess that they did not work properly, so You might try to hook them back up with stock sending units - I wouldn't pull the aftermarket mess out until you see the stock one working.
dougli1
