copper82
- Feb 7, 2018
- Lubbock
- Jake
- c1500
Hello all,,, when I'm cruising slow, the speedo needle will dance up and down. I can hear a rotational rubbing sound. When I hear the sound, the needle will jump up and fall back down until it gets the point where it jumps up and I hear the rubbing sound again. Then, once I get up to speed, there is a constant hum sound and the needle reads the speed I'm at.
I did some snooping around and found the cable can have kinks in it, be poorly routed or real dry. I looked and they do not appear to be routed in a way that would cause a bind.
I think it is just dry and needs to be lubricated. What do y'all think?
