So where do I start?
coachdtierney54
US
C30
First, I apologise in advance if I'm posting this in the wrong area.
I have a 1985 C30 with a 454. It's stuck in a forward gear (not sure which one). I'm ready to buy a rebuild kit, but my friend thinks the problem might not be within the transmission. He's not around to ask at the moment so I thought I would seek some advice here. What other issues might cause my tranny to stick? The fluid level seems good, and the color is red. What do you think?
Sent from my XT1254 using Tapatalk
twinturbo427
Florida
Phil
Suburban
Need More info
Assuming it is a TH400 trans, the place to start would be the shift linkage. Then when you have verified that the column linkage is acting in conjunction with the transmission, pull the pan and inspect the internal linkage.
What were you doing when it "got stuck in a forward gear" ?
Smokey burnouts?
5 grand neutral drop?
Power shifting full throttle from reverse to drive?
Or casually accelerating from a stop light? :rolleyes:
silverscottsk10
trafalgar indiana
mike
Is this while driving or stationary?
If stationary, Check shift linkage, comes out of the firewall and down, if the pin has fallen out, it can slip out of the cage and trans won't shift from the steering column, as far as being internal, that's more for @HotRodPC to diagnose
Sent from my SM-N950U using Tapatalk
silverscottsk10
trafalgar indiana
mike
Need More info
Smokey burnouts?
I have been beat to the reply lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Need More info
Smokey burnouts?
I sure hope if it was doing Smokey burnouts there is an accompanying video.....
twinturbo427
Florida
Phil
Suburban
The pic from the muffler post shows a TH400 pan.
I have never seen a TH400 stuck in a gear that wasn't related to linkage, or the internal linkage. I can't remember what it is called (the gate?)
Now, if it was able to be cycled to park reverse neutral but only had one forward gear, that is a different story.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The internal linkage may have come off. You know the nail fell out.
4WDKC
Southern Florida
Kacy
Surely he would be trying to get good mpg from his truck.
With the engine off, disconnect the linkage to the transmission and see if you can move it. If it moves without the shifter connected to the tranny I would check all the linkage for the bind and not tear apart the transmission. If the transmission is still bound probably will have to come out.
coachdtierney54
US
C30
I wasn't doing anything crazy. The tranny did not want to shift in colder weather. Had to let the engine get hot and then really had to revise the engine to go anywhere. It gradually got worse and now it's stuck in gear. The last time I drove it I lost reverse. I started it yesterday when it was warmer weather hoping for different results. Went to reverse - nothing. When I went into drive it felt like something broke. The shifter lever was very loose.
coachdtierney54
US
C30
That should have said rev the engine
twinturbo427
Florida
Phil
Suburban
Engine OFF, Chock the wheels, set the emergency brake, and have someone move the shifter while you inspect the action from the underside. If everything moves from the column to the tranny, it is time to drop the pan.
This step may seem futile but if it is a simple fix and you had spent a weekend benchpressing a TH400, you'll wish you had removed the pan.
coachdtierney54
US
C30
So what kind of parts should I be looking to replace if I do not have to do a rebuild? I'm on rockauto.com and there's not much to choose from regarding linkage for an automatic transmission.
coachdtierney54
US
C30
Just got the truck back from the garage. I'm back to driving again.
Sent from my XT1710-02 using Tapatalk
coachdtierney54
US
C30
I had a small leak in the transmission. I fried it. Had to get it rebuild.
kmousseau8
