Rubber Seal
custodian
Catawba
William
5.3 LS, 350
I replaced my heater core in my 73 today. I noticed when I replaced the inside heater box that there was a gap between the heater box and defroster duct work. Is there supposed to be a rubber seal between the two? When I removed it, I did not see anything on top the box.
Also, just want to make sure that the 3/4" hose goes to the water pump and the 5/8" hose goes to the intake. I have heat only on this truck.
My truck originally had a 250 6 Cylinder, now has a 357 V8.
Can't tell you for sure, but the parts dwg/list makes no mention of a seal at that joint:
Also, in my experience (and that of several others), it appears that - for some reason -the gap is there by design. The 81- 91 HVAC systems all have it:
custodian
Catawba
William
5.3 LS, 350
Thanks for the diagram. I do see a piece that I don't have, the outlet assembly, #14 on the diagram.
What I did for the gap was to put aluminum tape around it.
The heater and defroster works fine now.
yevgenievich
Viktor
sad
very sad
less sad
Mine hase foam filling the gap, tape also works
CRM
Pasco, Washington
Casey
K2500
350 CI
I've wondered the same thing ever since I replaced my heater core. I thought I hadn't put it back together correctly.
BiggG74
Pasco Washington
Gilbert
GMC
I changed my heater core this past fall and it had a material that had a type of insulation on cardboard backing that fit all the way around the box. It tore when I removed it. It got hooked on one of the bolts.
T3rraBeara
