Parking brake pedal
coachdtierney54
US
C30
Hi guys,
My parking brake pedal is currently held up by wires. If I remove the wires, the pedal slowly goes down and activates the brake light on the instrument panel.
Is there a way to tighten the cable for the parking brake or do I need to replace the cable?
As always, thanks for your input on this community truck!
Sent from my XT1710-02 using Tapatalk
coachdtierney54
US
C30
Thanks for the thread. I do appreciate it.
coachdtierney54
US
C30
So if I'm reading this thread correctly, my problem might be in the cable or the spring. Is the cable easier to get to? It looks like it from the pics.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Try adjusting the cable first. I recently rebuilt my rear brakes and had to replace one of the parking brake cables. I haven't dialed in the parking brakes yet as the motor is getting pulled. In my case the e-brake will not hold my truck, but I think that is due to the brakes being out of adjustment.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
There should be a thick wire running under the truck, and with the brake up it should be taught, not tight
kurt54
